- 18 Oct 2002
- Kuala Lumpur, Malaysia
I've just got a block of static IP addresses for our office, I've been given a block of 8 :
You've ordered a range of Static IP addresses, which contains 8 addresses from ***.**.**.185 to ***.**.**.189. Three of these are reserved:
* network address: ***.**.**.184
* router/Hub address: ***.**.**.190
* subnet mask address if you have 5 Static IP addresses: 255.255.255.248
* subnet mask address if you have 13 Static IP addresses: 255.255.255.240
I've never used Static IPs , so not sure how I go about setting these up/assigning these to a machine? I spoke to BT and they just told me they don't give any support on static IPs , he was addament that the router would still remain wit a dynamic IP, doesn't that defeat the point?
your machines should be setup to periodically submit data to the server...
