Hey guys,
Well, here's an interesting one. I've been shifting through the web for a couple of days now, looking for a new graphics card; which i've narrowed down to the following 2 cards:
XFX XFX NVidia GeForce 8800GT 512MB 8800 GT Alpha Dog
Spec:
# Memory Clock 1.8 GHz
# Clock rate 600 MHz
# Shader Clock 1625 MHz
# Dual Link DVI - Supporting digital output up to 2560x1600
# Chipset GeForce 8800 GT
# Memory 512 MB
# Bus Type PCI-E
# Memory Type DDR3
# Memory Bus 256-bit
# Highlighted Features
RoHS , HDCP Ready , TV Out , Vista , Dual DVI Out , SLI ready , HDTV ready
Price: £92
OcUK GeForce 9600 GT 512MB GDDR3 TV-Out/Dual DVI
Spec:
- GeForce 9600 GT core running at 650MHz
- Shader Clock Speed of 1625MHz
- 512MB GDDR3 Memory running at 1800MHz
- 256-Bit Memory Interface
- 64 Stream Processors
- Shader Model 4.0
- Memory Bandwidth: 57.6GB/s
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Geforce with CUDA
- PhysX enabled
- CUDA enabled
[http://www.overclockers.co.uk/showproduct.php?prodid=GX-093-OK&groupid=701&catid=56&subcat=356]
Price: £77.04
Aim to use purchace a card for gaming, at a resolution of 1440x900. Current budget is around £100.
What do you guys suggest? If you can recommend another card, then you're welcome to
Spec:
# Memory 512 MB
# Bus Type PCI-E
# Memory Type DDR3
Price: £92
Spec:
- Shader Model 4.0
- Geforce with CUDA
- PhysX enabled
- CUDA enabled
Price: £77.04
meh, not worth arguing
