problems outputting 5.1 from laptop
21 Oct 2002
My HP laptop has audio and video output over HDMI. When I connect it to my Onkyo 606 I can test all the speakers in control panel and everything functions.
When I play music from the laptop or play a game on my Panasonic 42" plasma sound only comes out from the 2 front speakers and the subwoofer.
Be grateful for any ideas.
If you play a stereo file and all you get is stereo on your speakers it's most likely that the player isn't even trying to output to your rear/center speakers.
Try using winamp, it outputs 5.1 for me even when playing back stereo files.
Also look at your amp it may well have some sort of pseudo surround mode that will attempt to distribute music across 5.1 speakers. Just keep in mind that the amp (or PC if you use the other suggestion) are making the decision about what frequencies go to which speakers. This will have nothing to do with how the music was originally mixed and may give some odd results at time.
On the Onkyo amp look at Listening Modes. In particular Dolby Pro-logic IIx
thanks
