- 11 Feb 2004
- TheWirral
Does anyone own this?
http://www.overclockers.co.uk/showproduct.php?prodid=MO-069-LG&groupid=17&catid=1120&subcat=
Screen Size: 27" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 20000:1
- Brightness: 400cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/170°
- Colours: 16.7 Million
- Freeview Tuner
- Inputs: 1x Analogue, 1x DVI-D, 2x HDMI, 1x Component, 2x SCART, 1x TV Aerial, 1x CI Slot & 1x Optical Out
- Dimensions: 654.0mm x 500.0mm x 210.0mm
- Weight: 9.0kg
- Warranty: 3 Years On-Site
apart from using this as a computer monitor I want to plug my sky+ box and Xbox360 Into It. Will them 2 products look any worse than on a "standard" HDTV set up ?
What Is the difference between this LG M2794D 27" and a HDTV?
I get the feeling this LG is a monitor but also lets you add standard stuff like sky+
where as a HDTV is a tv that lets you add a pc.
hope im making sence lol.
- Freeview Tuner
- Weight: 9.0kg
