Hi all,
I've recently finished a build and finally installed W7 beta on my raid array.
It all seemed to be fine, but when I went to startup after a night's rest the board wouldn't post.
The fans would all spin up, but there were no beeps or nothing.
I shut down from the power off button on the case, and restarted.
The board spun up, died, then reboooted again - again with no post beeps.
I took the box out, fiddled with connections, and thought maybe it's the GPU, so changed it to another pcie port, and third time it started.
restarted a few times, and all ok.
This morning, went to start, and exactly the same again.
I've tried to update the bios, but the BIOS won't see the USB stick I have - 4gb formatted to fat32.
When it decides to post, it boots fine and works like a dream, but it's almost as if from cold it just doesn't want to know.
Bios on board 1004
8gb corsair ddr2 c6400xms (the ones with big heatspreaders)
Q9550 CPU with an arctic cooling Freezer 7 pro (which is waaaay louder than my old CP9500 cooler )
NVIDIA Quadro 4500 running DVI-D
BT dongle
Be-Quiet 650W modular PSU with fanPWR lead on the motherboard
other than that it's just my V-raptor raid and the 500gb WD Green I use for backups etc.
Oh, and all the hardware apart from the GPU are brand spanking new.
This is starting to really dick me off.
Have I bought a duff board? is this a known problem or should I just return the peice of junk to the reseller and say give me an intel branded P35 board instead?
I'm getting very tired of all this - i'm sure it's something really simple as well, and i'm not seeing the wood for the trees!
All BIOS settings are set to factory default.
All help gratefully appreciated!
Bios on board 1004
BT dongle
