MKV to Xvid/Divx?
3 Apr 2007
South of the Watford Gap!
How the hell can I convert an MKV file which has MP4 video and AC3 audio to Xvid/Divx format so that my PS3 can play it. I know mktovob will do it but this results in a huge file. The other problem is that the MKV video is in HD so what would happen when and if I manage to convert it to Xvid/Divx?
So far I've had a look at demuxing the original so I have separate video and audio files but most things I've tried don't like the MP4 video. To add to the equation I would really like the keep the quality but as I've said above I'm unsure if I can.
Load the video, goto the video tab. Where it says video codec (h.264) change to xvid.
Knew I was missing something, thanks :)
Is there a way to say don't process but copy the audio as it seems to reencode it to MP3 and I want to keep it as AC3 5.1
I'll try and explain,
Load video
goto the audio/sub tab
select the source you want, then the next tab, Audio codec, select the output.
