A year or so ago, I worked for a vehicle leasing company,
& the average life expectacy of pads on the Focus & Mondeos we leased out, was around 15 - 20K
We had a few need pads & discs after 20K.
End of the day, it all comes down to how the car has been driven.
No, but all the pads on each axle should be changed at the same time. BTW pads come in sets of 4, one set for each axle.
yeah, but theyre probably charging an hour anyway.Seems kind of expensive to me, pads cost 35 and it will take 10 mins labour to fit them.
it's the front axle and they are quoting me £97.
Is that a decent price?
ive seen folk burn through pads in under 15000 miles.
Try paying for Porka brakes
probably as bad as the AP setup for the Vectra. Replacement disks are over 1k and that doesnt even include AP pads. The EBC yellowstuff ones are £86 for a pair, but if you want the original pads supplied they're more expensive still. Practically purchasing the entire kit all over again. And the kit is £1600.
1k for discs on a vectra, what size are they?
Edit: doesn't matter i've found them, £300 from Cortney sport plus £86 for the pads, thats just a little bit short of 1.6k for the kit?
