Oh yeh its a M reg 2.5 turbo diesel estate, Not as quick as the saloons cos of the extra weight.
Hi, I would suggest a specialist french garage and if they cant do it they will most likely refer you to someone who can. Clearly other xms pick up similar faults so it would be sensible to take to a specialist who has seen the faults before. If you are near manchester then take the car to Paris Autos (google them for the phone number) or ask Doug at Westroen Spheres if he knows anyone although he will probably refer you to Paris Autos. Another option is go to http://www.frenchcarforum.co.uk They may be able to tell you how to sort some of the faults or suggest someone to fix it. Finally...Join the Citroen owners club and they will certainly be able to help and refer you to a good specialist.
Nice car, pretty worthless now but mega interiors and quirky styling.
Also citroen has a awsome anti theft gadget, and I dont know why other manufactors dont use this. Basically you have to punch a 4 digit number before the car will start, If you put in the wrong number the engine will turn over but it wont fire up.
It shouldn't cost loads to fix if you go to the right place that has seen the fault hundreds of times before.
I have a Xantia Exclusive HDI estate btw.
Nah, that was pre key imobiliser, basically the old system to what all cars are fitted with now but without the hassle of typing in a number, they did it with some phase 1 saxos also iirc.
I really like these, not very common and i'd love to have one. Better than a lot of modern alternatives and pretty cheap to buy too.
Be a shame to scrap it for electrics, but may not be cost effective unless you don't mind getting your hands dirty
