thermal compound
yeh its gotta make proper contact .. put slightly less around the edges and very slightly more in the middle. :)
is the bottom of the heatsink completely flat, test it on something flat like a mirror, it should not rock at all.
bottom of the cooler is completely flat, as is the cpu, its idling at 50-55, ive never had it idle at lower for a long time, when it had the preapplied paste on it started at 40-45 then shot up to 50-55 idle, im just gonna let this artic silver burn in for 200 hours and see whether that helps.
i think to be honest its the cpu model, its a 95nm process technology, runs at 125watts and that means creating a lot of heat.
The smallest quantity of IPA I could get was 1 litre, that'll last me 'til the end of my days, but it's the best at getting thermal paste off a CPU, makes it nice & shiny :) Use a credit card to scrape a small amount accross the surface of the CPU, a REALLY thin layer, much thinner than 1mm. All thermal pastes are electrical insulators.
Over apply the thermal paste and the heat has to get through it rather than though the metal of the heat sink, hence higher temps. The thermal paste is there ONLY to fill in the minute gaps between the surfaces of the CPU & the heat sink.
We buy IPA in bottles of 25L at work. I must have a life time supply on tap!
gladly the compound did cool and is working really well in my system after like half a year of use :) totally happy with the stuff :D
AS5 needs time to cure and become effective whereas MX-2 does not require any curing time. This is why it took a while before your temps came down.
I apply the equivalent of a grain of rice and let the cooler spread it out. Not that much is needed really and too much can act as an insulator.
The grain of rice size has been around since the athlonXP without a heatspreader, i.e. a bare silicon CPU. For a newer CPU with the larger area heatspreader, you may need a bit more. I put enough AS5 on to spread very thinly over the whole heatspreader probably 0.25 to 0.5mm thick and burn it in for a while on full MHz like 8-10hrs. This should provide optimal results. Too much and it does leak out of the sides under pressure. This is not usually a problem but can look messy. Akasa TIM is good, as is a bank card used as a spreader for the goo.
