1k for discs on a vectra, what size are they?
Edit: doesn't matter i've found them, £300 from Cortney sport plus £86 for the pads, thats just a little bit short of 1.6k for the kit?
shame you cant read
I think it's a reasonable price too. They'll probably replace wear sensors, and caliper bolts too. It isn't a 10 min job to do properly. They're your brakes for gods sake - pay the money.
Dont they come in the box? Every time ive purchased front pads they have came with new caliper bolts and wear sensors.
shame you cant read
I was under the impression the AP setup was the standard disc size and items fitted to the VXR out of the factory, lets face it looking at upgraded brake parts from your VXR vs his standard Porsche part prices is hardly correct.
the rear pads are £35 online
the front ones £55?
i really don't know anyone that knows anything about cars sadly ...
shame you cant read
Its very strange, but then again the amount of replacement discs AP racing must sell has to be rather low, not had chance to fully check the link but is the 345mm AP racing setup based on a Hat and Disc setup, could explain the extra cost if the disc price is for both?
OP, 35k on a set of pads is nothing but magical, i find it odd that people feel things such as brakes should last forever or something!
My pads last about 10 - 15k!
Fronts are £35 from Brakes International. 10 minutes a side if you do a plain swap, 30 a side if you are greasing and cleaning the sliders. Job done.
Or you can pay someone £97. Sounds like you'll have to if you don't know anything about cars and don't have any tools.
the front ones £55?
lmao thats for Calipers as well, which is where most of it is going.
Try paying for Porka brakes![]()
ring and ask Courtenay how much a set of replacement rotors are the kit and report back on your findings.
I don't like doing engine braking
If you pay anymore than this you are wasting your money!
