Thousands of scratches...
24 Jun 2007
Landan.
I made a stupid mistake. My windows had been perpetually dirty, and I'm a bit of an obsessive when it comes to clean windows. So after washing my car and the windows, and seeing that the windows were still dirty... I decided to get out the scouring sponge :(
"It doesn't scratch non-stick pans" I thought, and as I set about cleaning the windows I could feel resistance where the dirt was, and presuming that it was the dirt in question, scrubbed harder :(
After washing the soap off, the windows were crystal clean. Get in the car, and it is then I notice the thousands of tiny scratches across my entire windscreen and side windows :(
I thought I could live with it, but as soon as any light hits the windscreen, it becomes virtually opaque. Is there anything I can do other than pay the £100's to replace them all?
And just for good measure, :(
you could try some jewellers rouge and a machine polisher
assuming you dont have any of these, brick your windows to hide the embarassement and get them replaced :p
Seriously...what were you thinking ?
I know, the look of shame my pa gave me when he came out said it all. I think he's disowned me, haven't spoke to him since :p
Anyone else clarify this might work? Not that I don't trust you!
Can I ask what posessed you to compare car windows to non stick pans?!
My logic was: scourer doesn't scratch the teflon on the pans, and glass is harder than teflon, and if I (gently) rubbed a metal spatula across a teflon pan, that'd scratch it, whereas it wouldn't scratch glass. Flawed. In so many ways. :(
It was one of those, clean first, think later situations.
Thanks for the sympathy! :p
I feel for you there, I really do...
A friend of mine let his daughter and her friend (about 9 years old) wash his FTO a few years ago and they decided to use the scouring side of the first sponge they found...
When I initially saw it I casually mentioned to him that he had forgotten to polish the swirls of wax off the body work as that is exactly what it looked like. He then told me the story :D
Thankfully - I know a scourer beats paintwork in a game of rock, paper, scissors so steered clear :D
No worries,
If you smash your windscreen, your insurance company will usually take care of that with just paying the excess (50-60 quid) usually.
As for the side windows, no idea :(
Didnt think you were meant to use a scouring brush on teflon pans either?! Back in the olden days living with my parents my mum used to go mental at me so it's burned in never to use a scourer on a Teflon pan. I think she used to love her frying pan more than me :(
No worries,
That'd be fraud though wouldn't it... ;)
I remebered seeing an article on DW about a scratched windscreen so dug the bookmark out.
http://www.detailingworld.co.uk/forum/showthread.php?t=95965
Whilst it might not be practical for you to correct it, It may be possible to find someone on DW willing to do the work for a cheaper price then getting your glass replaced.
Again, big thanks for that - going to see if my dad's speaking to me and whether he's got a rotary polisher (right term?) :D
