Whats using all this space?
4 Feb 2007
Nuneaton, UK
I ordered 2 Samsung 64Gb SSD's yesterday from work so I will have a 128Gb C: drive.
Last night I check and my C: drive is currently 114Gb :eek: but looking at the size of the folders it didn't add up.
Vista Ultimate 64bit installed with Office 2007 and COD4 is the only game installed. Anything I down goes on to my storage drives so I don't understand what is using all the space?
I need to ghost this drive and would rather it wasn't so big and also don't want it filling my new drives.
I will run Ccleaner when I get home, is there anything else I can do to free up some space?
Thanks
system restore
'previous versions'
disable system restore
delete all the points -do this in 'cleanmgr', more options, cleanup.
then click start, type cmd, rightclick it, 'run as administrator'
paste this into the cmd window.
vssadmin resize shadowstorage /for=c: /on=c: /maxsize=300MB
that will set the max size for 'previous versions' and what not to 300mb (that's the smallest you can set it to)
along with ccleaner, should free up multiple gigs
Windows updates? C:\Windows\SoftwareDistribution\Download
Shouldn't be using that much but might be able to few a fe GB's
Thanks guys, I will have a look when I get home.
I also need a good Ghosting program to ghost my OS if you know of one.
Yeah don't Restore Points suck... checked last night and I had 13 restore points taking up 100GBs :/
Is that all dos based? As I need to ghost my OS from my raid array to my storage drive, then create new raid array and ghost it back on. I have a feeling this isn't going to be fun.
Have a look at the WinSxS folder and watch her grow. This folder is used by Windows Side by Side and allows Vista to keep tabs of differing versions of the same DLLs which may be required by some programs but it effectively produces cabinet type files with many duplicated DLLs so just grows and grows as you install software.
Well I just sorted it, I'm truly gob smacked.
I followed bledd's steps in post #3.
Before my C: drive was using 115Gb of space and now its 38.7Gb! Amazing.
Thanks.
Now to ghost my OS onto my new SSD's.
