Caporegime
- 13 May 2003
- Warwickshire
Hi all
Just had a 50 gal tank installed in the loft now that we have a power shower in place of the 25 gal one we had before. They've done the job today and all is well except for two issues:
- they've left the plastic shavings from the drilling in the tank, which is now full. I'm worried about this damaging the pump or blocking the various filters in the cold water network.
- the hot water vent pipe from the cylinder downstairs has been fed a hole about 2cm wider than the pipe itself. I thought they were meant to be protected to stop insects getting in? The lagging is present and correct, just this issue with the vent pipe.
Should I be concerned or is this normal? I'm going back to pay tomorrow but before I pay I want the job done to a sufficient standard.
