**** This Week Only ,Dell UltraSharp 2209WA £183.99
Lenovo 22" L220X 6ms DVI LCD TFT 1920x1200 *samsung S-PVA pannel*
what type of pannel is this ? £290 i seen it for ;P £100 more granted lol but its 1920x1200 on a 22" pannel
EDIT: found out what pannel type it is ;) hmmm this just might be the monitor im looking for lol
1680x1050, << that speaks for its self..
it can be a super duper godlike epic awsomeness but peoples choice on it will come down to the resolution.
The resolution actually means very little if the image itself is terrible. And if you're buying for business you need a height adjustable monitor, which most of the cheap ones aren't.
These are high quality, rather than meaningless high specification.
I have just got one of these at work and I am pleased with it so far. It needs a bit of adjustment to get the colours right. It has tilt and hight adjustment.
I'd say 1680x1050 at 20" or 22" is about the sweet spot with monitors right now, both for home and business use. Enough resolution to be useful without being too large. Basically the widescreen equivalent of the old 1280x1024 stalwart.
Pretty sure the Samsungs are TN panels.I actually bought the dell 23 inch TN panel before Christmas,probably the best TN screen i have bought
But for me any screen above 19inch which has a TN panel i cannot stomach....
