You may run into problems here. I've got a 8800gt with a thermalright passive cooler. Its fine under minor load with no airflow, but when loaded it'll kill itself if deprived of air. And thats not a particularly quick card these days.
Properly fanless psu is difficult too. Theres two on the market I believe that will function with zero airflow, and at least one of them is externally mounted.
I settled on a compromise. I had a heavily overclocked computer with many many fans in that worked quickly and played games well. The passive gpu was fine as a consequence of so many fans
When playing games or doing computationally intense things I coped with the noise. When watching films, browsing the internet etc, I rebooted into an underclocked profile and then turned off the fans in software. Using a TRUE which works fine passively, and a film hardly stresses a gpu.
Only thing I failed to achieve was the psu, as I wasn't brave enough to risk connecting the psu fan to the motherboard in order to control it. A dead 800W psu would suck badly.
Is there anything more specific youd like to ask? Silent is very very hard. Very quiet is fairly easy
(overclocking and silent probably means water and a lot of care with the pump)
