- 24 Feb 2009
- Teesside
I know its a useless processor for games, the L2 cache is tiny etc etc, its hopefully just filling a gap until I can afford somthing a little better.
Anyway, Im not completely new to overclocking and I know this processor is capable of more, I just cant get there and am not sure why! The photos show my current settings. Ive basically increased fsb to 300, upped the vcore (its over 1.5 on this but boots at 3Ghz with about 1.47) and set the "system memory multiplier" manually. Also changed the voltages slightly for the DRAM and MCH (northbridge right?).
Ive also disabled some of the settings in here
Most guides say about setting the RAM divider, guessing thats the same as my memory multiplier? Just worked out differently? I can get mine to set my RAM frequency to just over 900 before it becomes unstable.
Also, Ive read about setting the NB strap, is that "MCH frequency latch" on mine? Ive heard that I should set it as high as I can (over 1000 I was told) but the highest setting for it is 400Mhz at which point my PC wont boot anyway.
Anyway, you can see my settings as they are. If I raise the fsb even by 5Mhz it wont boot, even when I raise my vcore upto around 1.54 (like I said, it boots as it is at about 1.47). This makes me think it must be some other settings? Or have I just reached the limit for this chip? Hope not as Ive seen quite a few running 3.4/3.5Ghz
Thanks for any help
Thanks for any help
