i7 o/c & dram voltage - 1.58 too high?
11 Apr 2007
Ive been slowly increasing the blck on the cpu and now have it at 175 which gives me 3.66GHz with Turbo Boost enabled.. (or 3.5GHz in the bios) Everything seems stable although I do have to do longer stress tests.
My query is that because I've set the dram volgate to auto its showing a voltage of 1.58V.. The corsair ram spec says it should be running at 1.5V.. Is this an issue? Should I manually set it to 1.5V so it doesnt overvolt?
still learnin... :eek:
ram I'm using is: 6GB CorsairXMS3, DDR3 PC3-10666 (1333) CAS 9-9-9-24
