i need it for the laptops on the other above 2 floors.
i just looked WALL-PLUGGED RANGE EXTENDER - WGXB102 so all i have to do is connect these to the sockets in each floor or room and the wifi will be picked up.
There may be some configuration involved for the wifi rather than just plug and play, however if you can configure a routers wireless settings fine then these should be no problem.
