**Official [OcUK] Quakelive thread**
Just had a few more games and i love the fact that most players panic as soon as someone runs towards them with the gauntlet! Needless to say the gauntlet is still my favourite weapon lol
On another note is it me or is the rocket launcher a lot more powerful than it was in Quake 3 Arena?
My username is OcUK_mrk :D
Going to play some tonight but probably a bit later in the eve as I have some outage to do before then \m/
I've added everyone to friends list, awaiting confirms :D
Bark!
Now I remember why I stopped playing Quake 3 :p
Although I love gauntlet-slashing people!
Gotta love ID software :)
Nick : DeathW1sh
I've had to make a new login as my early closed Beta account appears to have been nuked :(
Incase anyone needs here are some usefull commands...
you can find you config in... (for vista64)
C:\Users\Username\AppData\LocalLow\id Software\quakelive\home\baseq3
console active using CRTL+ALT+¬ (tilde key)
First command your probably want is..
com_allowConsole "1"
type /clan <clanname here>
Then the following if you like
cg_forcemodel "0"
cg_forceTeamModel "xearo"
cg_forceEnemyModel "tankjr/bright"
com_maxfps "125" Sets the max, think this is default.
cg_fov "110" for Field of View
cg_drawFPS "1"
cg_bob "0" this sets bob to 0 which means you charecter wont move up and down when moving etc.
cg_railTrailTime "400" Good for seeing where the rail came from before it disapears.
cg_drawgun "0" Removes the weapon, i've always played with this
Nick : DeathW1sh
cg_forcemodel "0"
cg_drawFPS "1"
That is some beautiful information! Admitadley I haven't looked much but have been meaning to get FOV 110 and forcing people's models , so this is excellent :)
Thanks for the info deathwish!
Any way to blag the install of this on a PC where you don't have admin privileges..? *cough* :p
To the above dude having problems. Have you tried say installing FireFox into :
C:\Documents Settings\USER NAME\ folder?
If so you usually have permissions to run and isntall stuff there. Install FF into that folder somewhere, then try using the plugin and downloading it all to there.
Might work?
Here are some other usefull commands I use, from my config:
Display:
seta r_picmip "15" - if you want to remove all detail from the maps basically, makes it cleaner.
seta r_dynamiclight "0" - 0 removes rocket flash, etc.
seta cg_lagometer "1"
seta cg_simpleitems "1" - 2D icons for weps / ammo / pickups
seta cg_scorePlums "0" - Removes floating score bubbles, eg. "+1"
seta cg_kickscale "0" - Stops the screen from shaking when taking damage
seta cg_bob "0" - Makes your screen stay straight when jumping and hitting the ground
seta cg_noprojectiletrail "1" - Removes projectile trails
seta cg_brasstime "0" - Removes bullet brass dropping everywhere..
seta cg_drawfriend "0" - Removes the yellow arrow above friends
seta s_ambient "0" - Removes ambient sounds like rain on qztourney7
seta s_musicvolume "0"
seta s_doppler "0"
seta bot_nochat "1"
seta cg_crosshairPulse "0" - Stops crosshair "pulsing" when you pick up an item.
seta cg_drawgun "0" - 1 = show, 2 = show without weapon bob (1 or 2 needed for thinshaft)
Network:
seta rate "20000"
seta cl_maxpackets "125"
seta snaps "60"
seta cg_predictItems "0"
seta cl_packetdup "2"
seta cg_smoothclients "1"
RG :D - Pink beam !
seta cg_railTrailTime "1500" - Rail stays untill reload time is up.
seta r_railSegmentLength "32"
seta r_railCoreWidth "4"
seta r_railWidth "0"
seta cg_oldrail "1"
seta color1 "6" - Pink
seta color2 "6" - Pink
My crosshair (Pink dot):
seta cg_crosshairsize "24"
seta cg_crosshaircolor "6"
seta cg_crosshairhealth "0"
seta cg_drawcrosshair "6"
You can specify FOV, sens, drawgun etc. for each weapon bind, for example;
bind 1 "weapon 1; cg_fov 110; sensitivity 4.50; cg_zoomfov 55; cg_drawgun 1; cl_mouseaccel 0; cg_gunz 0 ; cg_gunx 0 ; cg_guny 0"
Or;
bind 2 "weapon 2; cg_fov 110; sensitivity 4.50; cg_zoomfov 55; cg_drawgun 0; cl_mouseaccel 0; cg_gunz -10; cg_gunx -10; cg_guny 2"
I use a custom HUD also, this is what my game looks like;
With picmip 15
With picmip 0
I swich between the two..
I have constat 125 fps, think taking the screen made it go down to 121 :o
Thanks to Emsixteen for the HUD :P
The first screeny looks like ass though! it's like as if a bunch of ****** hauled ass into the scene and smeared ***** poo all over the box!
