Countif
16 Oct 2007
UK
Dear all
In excel, i have a question...
I have am trying to do a COUNTIF, but based on different criteria range.
I basically want to....
COUNT A1:A50 if B1:B50 = "Bar"
Any ideas?
Thank you!
Hello,
I think you have to use following formula for the same :-
=SUMPRODUCT(($A$1:$A$50&$B$1:$B$50="Bar")*1)
Put this formula in that column where you want your answer.
So you want a count of the cells in column A where the adjacent cell in column B is "Bar". Is that not the same as counting all the cells in column B where "Bar" is written?
Or do you want to sum all the values of Cells in column A where the corresponding cell in Column B is "Bar"? If so see my equation below :)
Hello,
That didn't work for me, did you mean =SUMPRODUCT(($B$1:$B$50="Bar")*($A$1:$A$50))
But that will sum not count the cells in A1:A50 where the adjacent cell in the B column is "Bar".
To count the cells in column A adjacent to cells with "Bar" in column B you'd just use =SUMPRODUCT(($B$1:$B$50="Bar")*1) but like I mentioned before that would just do the same as counting the occurrences of "Bar" in column B :)
Could you please let me know which excel version you are using and if possible attach a sample file or else let me know the expected output.
