Both specs looking good...anyone know if there is anyway to squeeze an I7 spec out of my budget?
That 1st spec won't work, because the phenom II 940 doesn't support AM3 + or DDR3. It needs to be run in an AM2+ board with DDR2. Only the newer Phenom X3 720, X4 810 etc support DDR3.
Secondly, you can save money by getting An AM2+ board and DDR2 memory for ANY of the CPU's, because they all support DDR2. I'd be inclined to do it that way if you go for phenom II.
You're right, my bad, must have had a compo moment, dont know what I was thinking, sorry
substitute in the X3 720, very capable and save you £50
