- 26 May 2008
Hi all,
I am just contemplating my next build, and putting a short list together of stuff to get over the next few weeks, and was wanting a short list of the better recommended P45 motherboards.
Budget will probably be £100 to £150, I want an easy cable management, no worries of graphics cards getting in the way of sata
, and an easy to work bios, with some sort of safe easy to reboot feature, my current Asrock is quite nice and simple in that all I have to do when something goes wrong, is power down for a few minutes, and reboot back into Bios to change problem settings, simple.
I will probably use the E5200 from my current machine, and probably end up with 4Gb of Dominator PC-8500 or such with an E7400 or E8400.
I also have a rather large Scythe Kama Angle CPU fan I would like to use, so I am trying to take this, plus the dominator fan (IF I get such), and the chance of a long graphics card into consideration.
Biostar TPower I45 Intel P4 is one option I have looked at, but does the fan on the back of this mother board intrude? And are the voltage options in Bios easy to understand?
What Asus and Gigabyte motherboards should also be considered?
EDIT, Would I be better off with DDR3?
Thanks,
Steve
Thanks,
Steve
