Cheap work upgrade..check for me.
26 Jan 2006
Belfast
Nothing special, more jus tto boost things abit, tho havent built a PC for years as im solid at home so out of touch with components, if yas could take allok and make recommendations, much appreciated as usual thanks! :)
God imageshack really is usless now!
Intel Core 2 Duo E7400 LGA775 'Wolfdale' 2.80GHz (1066FSB)
Zotac GeForce 9800 GT 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - R
Abit IP35 Pro XE Intel P35 (Socket 775) PCI-Express DDR2 Motherboard Abit IP35 Pro XE Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
Kingston HyperX 4GB (2 X 2GB) DDR2 8500C5 1066MHz Dual Channel Kit (KHX8500D2K2/4G)
MAYBE Vista ultimate, but will prob just stick with Xp for work so its solid..well...more than.
umm good question, not sure whats in this machine, is there a way to find out?
Or what would i NEED for it?
Support could be a problem with the Abit board as the parent company have quietly announced they are pulling out of the channel completely http://forums.overclockers.co.uk/showthread.php?t=17983450&highlight=abit.
Looking at your memory the Corsair XMS2 PC2-8500C5 TwinX 2 X 2Gb is on "This Week Only" and slightly cheaper (and slightly better imho) than the Kingston - http://www.overclockers.co.uk/showproduct.php?prodid=MY-173-CS&groupid=701&catid=8&subcat=817.
I'm guessing but think a minimum of 500w Power Supply for that rig?
Happy Building :D
WhiteKnight
Seen the Corsair and was tempted, but seeing as the boos has to pay for it, I cant count on him getting this buy the time this weeks out.
What would I do about the motherboard, Gigbyte?..have a DS4 but had to grind down my Ninja HS to get it to fit cause of the long life resistors wasnt it?
