PHP? > PDF
10 Feb 2009
Hi there, i hope someone can point me in right direction
i dont know any PHP to be honest but im assuming this is whats needed for this
Basically i would like a webpage for our firms intranet that allows you to enter an order number into a field and this will then bring up that order numbers PDF document
in other words, if i save a pdf document onto the network - or even upload it on this page, and name it 180642 i would then like to be able to come back in a few weeks and enter 180642 and this will display this pdf document i created previously
i hope this is clear and i hope someone can help on this...
Many thanks guys
Doesn't need to be done in PHP... it's page with a search function is what it sounds like... could be asp, aspx...
Okay so pretty new to PhP myself but it should work something like this:
have "search.html"
<html><title> daniel545's super search page</title>
<h3>Enter the Order No:</h3>
<form action="get.php" method="post">
No: <input type="text" name="no" />
<input type="submit" />
</form>
</html>
Then have get.php as
<html>
<body>
Click open open the order <a href="where_i_save_my_order_pdfs/<?php echo $_POST["no"]; ?>.pdf </a>
</body>
</html>
its going to be on a linux server if that helps
any ideas where i could find the info to create this?
doesnt have to be anything fancy at all
cheers
cheers
You'll need to install apache, then put your put PhP code in
/var/www/html
Google PhP help and you'll find lllooooaaaddddssss of tutorials on PhP
i cant seem to get this working using this
just to check in the href do i use the url or the file path?
im currently using the url and i get to the search fine - i enter the number and i then get this
Click open open the order <a href="http://internalurl/testing/test.pdf
it looks like a simple error but could do with a pointer...
cheers
have "search.html"
</form>
</html>
<html>
<body>
</body>
</html>
you know that the code above should be on 2 pages?
e.g.
this file called whatever you want
Code:
<form action="get.php" method="get">
</form>
</html>
this file is called get.php
Code:
<html>
<body>
Click open open the order <a href="where_i_save_my_order_pdfs/<?php echo $_GET["no"]; ?>.pdf </a>
</body>
</html>
notice i changed the method from post to get as i see no reason for it not to be, makes life a little easier as you can easily change the pdf you are viewing by changing the value in the url :)
yes i have two pages
one called search.html and another get.html
i have tried your code and its still failing
im still getting the same error as before
"Click open open the order <a href="http://internaladd/testing/test.pdf"
any ideas?
e.g.
Code:
</form>
</html>
Code:
<html>
<body>
</body>
</html>
Looks like your missing an extra > in get.php, try this:
Code:
<html>
<body>
Click open to open the order <a href="where_i_save_my_order_pdfs/<?php echo $_GET["no"]; ?>.pdf">Open</a>
</body>
</html>
