Hi
I have just purchased the graphics card in question in the title and am having the same problem on two serpate operating systems, both of which had been installed for a while and then I did fresh installs of both. The operating systems are Win 7 64bit and Vista 64bit - both on the same but on dual boots.
I turn on the PC, the operating systems boot fine but then when the desktop loads it either crashes straight away (in Win 7's case) or it will crash either straigh away or after 2-3 mins in Vista's case. The crash effect is that lots of horizontal, squiggly lines appear in various colours (mainly purple), it will sit like this for a while, then after a few mins the sctreen will go back and the monitor goes onto standby. I usually have to do a hard reboot at this point.
I have tried updating graphics drivers but to no avail and I really do not want to roll back drivers to an old version as the reason I bought this card was for CUDA support that my 8800 GTS 320mb did not have with Coreavc.
I doubt power is an issue as I have a 600w PSU that worked fine with the 8800. I also ran Nvidia system monitor utility that shows my CPU temp is 36c and my graphics temp is about 44c at the time of crash, so I also doubt this is the issue. My Asus bios is also up to date with at 1301.
Also my graphics card only 6 pin power connector when on various websites describing this card it says it should have two, could this be a problem?
I have read on other forums that there may be a problem with the bios on this graphics card but the people in the other forums generally encounter this problem only after playing games for a few hours where mine is on boot up.
Any help would be grealy appreciated.
My sys specs are as follows:
Graphics: BFG GF 9800GTX+ OC 512MB
PSU - OCZ GameXStream 600w Silent SLI Ready ATX2
Motherboard - Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2
RAM- 4GB
Processor - Intel Core 2 Duo E6300
Many thanks in advance.
B.
RAM- 4GB
B.
I am hoping that it goes completely mental on them.
