Firefox 3.1 beta 3
The .exe file you download says 3.1 beta 3. Though I would have thought all beta 2 would automatically upgrade.
I checked for updates when I visited the link, and it says none available. Must be very early in release? In any case since beta 3 is apparently out, thanks to the OP I'll grab it now.
Edit: The download was beta 2 as well :confused: Did you download a language other than British English or something?
n/m Jimlad's link saves the day \o/
On a side-note, I also took this opportunity to upgrade from Thunderbird 2.0.0.19 stable to 3.0 beta 2. It's a nice improvement, though I've not had it long enough to comment on much more than the improved UI. :)
Does Hotmail actually work in this beta?
EDIT: Finally the tab button is back. You can put it in its proper place again.
EDIT2: Hotmail works.
Hi,
i am trying to find my firefox profile manager so i can use the current 3.0.7 and try the 3.1 beta 3 at the same time but i am unable to find it when searching for "firefox.exe -profilemanager" or "firefox.exe -P"
any ideas
