Simplicity + Unlimited internet, Cheapest option?
31 May 2005
Alfreton,Derbyshire
Ok I was paying £15 for o2's simplicity tariff, but rarely use anywhere near the minutes and texts. I have just looked on the net and they do a tarrif for £10 a month for about the same as my original tariff. So now I have a £10 a month for 150mins and 300txts which is more than enough for me, it's just ashame their web bolt on is £7 which would put my tarrif back to £17 which isn't bad but i'm wondering if there is a cheaper way to get unlimited data? Cost a fortune whenever I use it otherwise.
Cant you get Web on the £15 instead of unlimited o2 to o2 calls? If you cant I would not go for £17 per month - beter off going for Simplicity for £19.50 which gives you 600 mins and 1200 texts ... I know you dont use that amount of mins tho.
Anyone actually managed to do this?
I used to be on the £15 and asked for unlimited o2 to o2 calls... now on £19.50 and recently changed to unlimited web as never got thru my 600 mins let alone o2 to o2 calls.
