I like it - as stated though, unlucky on the price.
I think these forums are quite strange though - 99% of the new car threads on here have some pretty dull cars (I don't want to see another picture of a mondeo!), you've choosen something you like, with good potential for power later and not as common as muck - good choice!
One thing though - do Jap cars come over here with KM on the clock or Miles?
KM I'm not converting the speedo, at least not until I know for definite if I have HICAS or not, since if I do have HICAS then the speedo conversion can make the car quite dangerous.
HICAS is Nissan's 4 wheel steering system, at low speeds the rear wheels turn in the opposite direction to the fronts, which helps with the turning circle, at high speeds the rear wheels turn in the same direction as the fronts to help stability during lane changes.
If you do the speedo conversion, which is done by putting a gearbox on the speedo cable, it buggers up the ECU's speed reading, you can be doing 40mph and it'll think you're doing just 40kmh (ie. ~25mph) so the wheels will turn the opposite way when you go to change lane. Not good.
After the conversion, the odometer will start counting miles, but the existing number will remain unchanged, in kilometers, so the reading will be wrong (too high) best to just leave it in kilometers.
Also I'm loving the barge comments it really doesn't handle like a barge. I upset an MX-5 driver on the way home tonight by overtaking him on
this bend, then watched the guy drive like an utter tit through Usk to try and catch up with me (a few more cars had gotten between us before Usk) and tailgate me all through the 30 and 40 sections. (Note: No speed limits were broken by me, that bend is a 70 limit)
Oh, and Gobbo, your mate actually owns a little black Lotus
