Virtual Clonedrive - Update Thread ( works with windows 7 )
Caporegime
8 Sep 2006
On Ocuk
http://www.slysoft.com/en/download.html
Virtual CloneDrive 5.4.2.5: 2009 03 10
- New: Added option to keep history of last mounted files
- New: Added support for unicode filenames (Windows 2000/XP/Vista)
- New: Added support for UTF8 image names in .dvd files (Windows 2000/XP/Vista)
- New: Sets media type (DVD, BDR) by parsing the image, if no .dvd
file is used or the .dvd file doesn't contain a media type
- New: Added /b command switch to VCDMount.exe to browse for image
- New: Added /h command switch to VCDMount.exe to clear history
- New: Added support for Windows 7 (beta)
- New: Added support for Windows XP 64bit and Windows Server 2003 64bit
- New: Added daemon.exe tool so 3rd party applications written for
Daemon Tools can be used
- New: Added "Virtual Sheep" for 64bit OS
- Change: "Buffered I/O" setting in VCDPrefs is now in effect
for files mounted over the network (default is off)
- Fix (Windows 2000/XP/Vista): Some reliability fixes
- Fix: VCDPrefs could hang when clicking "OK"
- Updated languages
- Some minor changes and improvements
What exactly do you mean by 'spyware packaged'? It was always fine back in the days when I used it.. ie 3.xx and early 4.xx
I currently have Deamon tools installed (I installed it without the spyware ;) ), any reason I should uninstall it and install this?
Deamon tool always made me want to smash my machine up, Virtual CloneDrive always made me want to give it a big hug.
I've got copies of nearly all of SlySoft's products including Virtual Clonedrive and they are all top notch. Seem to be a great company always offering discounts and updating their software regularly.
the other products are expensive for us now, because of the exchange rate. i own anydvdhd though :)
they release so many updates, it's unreal
I must admit I got the software a while back when the exchange rate was good. I've got AnyDVD HD, CopyDVD, Virtual Clonedrive and CloneDVD mobile. Plus I got it when the only license was the lifetime license. It is quite expensive software but it is more than worth it.
