If you haven't i recommend it.
Permabanned
1 Oct 2008
Town called Malice
Duel screens, just set it up this morning its brilliant. I knew i had a spare screen but someone had half inched the fuse out of it, but now its up and running and how did i ever go with out it ill never know :)
Going to have to take a picture and put it on the picture your desk thread :D
Dual screens where the monitors are not the same size is ugly and annoying. Possibly only exception is if they're the same brand - but they should be anyway!
Not really, I have my 24" Nec for main use with a little 15" for monitoring software and for listening to music. It works rather well :)
it's real handy for work, but at home, i only really use steam.exe now, so i just have the one big screen :)
Nearly every response in this thread shows the maturity of a 5 year old, get a grip.
He was just sharing his delight of getting two screen and that he would recommend it... honestly, bunch of idiots.
Nearly every response in this thread shows the maturity of a 5 years old, get a grip.
He would have probably had a better response if he'd posted in the correct section ;)
