How to make Windows Update window appear maximised when I open it?
7 Mar 2005
LU7
Following on from http://forums.overclockers.co.uk/showthread.php?t=17753962 I would like to make it so that when I run the Windows Update shortcut on my Start menu the window for Windows Update appears maximised across the whole screen and not in its reduced form.
I've briefly tried the above method on Vista x64 and I can't find anything that looks like being the way to get the Windows Update window to be maximised.
Does anyone know how to do this or are confident it isn't possible in Vista? I just hate having programs and utilities run that aren't maximised and that I can't force to be maximised.
I've checked the shortcut and the wuapp.exe itself and I can't alter the permissions for it.
Or if starting it from the Start menu you could have altered the properties for the shortcut, set Run to Maximised.
