**Kingston DDR PC3200 Now In Stock** From £16.09 Inc VAT.
15 Feb 2006
Staffordshire
Kingston DDR PC3200 Now In Stock from £16.09 Inc VAT.
ValueRAM's KVR400X64C3AK2/2G is a kit of two 128M x 64-bit (1GB) DDR400 CL3
SDRAM (Synchronous DRAM) memory modules. Total kit capacity is 2GB (2048MB). The components on each module include sixteen 64M x 8-bit (16M x 8-bit x 4 Bank) DDR400 SDRAM in TSOP packages. Each 184-pin DIMM uses gold contact fingers and requires +2.6V. The electrical and mechanical specifications are as follows:
- Clock Cycle Time (tCK) 5ns (min.) / 10ns (max.)
- Row Cycle Time (tRC) 55ns (min.)
- Refresh Row Cycle Time (tRFC) 70ns (min.)
- Row Active Time (tRAS) 40ns (min.) / 70,000ns (max.)
- Single Power Supply of +2.6V (+/- .1V)
- Power (IDD0) 5.408 W (operating)
- Operating Temperature 0o C to 70o C
- Storage Temperature -55o C to +150o C
- UL Rating 94 V - 0
Buy Now.
Prices dont make sense. you may aswell by two seperate 512 sticks than the bundled 2x512 as its cheaper by nearly £10
very true, strangely priced there.. also its a sad day when DDR1 is getting to be the price of DDR3 ram. I can't personally see OCUK shifing much of these.
I can. DDR carries a premium on the MM and is normally massively sought after.
And the extra is because it's a 1GB stick. If you want to work to 2 sticks maximum (which most do), you're limited to 1GB with the 512MB ones.
People still want them, simple as that. Prices can be adjusted. ;) but as TUTE says, you're missing the point there m8 :D
