How much have you spent?
Caporegime
1 Nov 2003
Lisbon, Portugal
Excluding tax, fuel, purchase and insurance...how much have you spent on your car since you have owned it?
Off the top of my head:
Tyres + tracking £450
Full Service £300
Camber adjusters £300
inlet plenum + vis valves £300
uprated brakes £300
Rear lights £40
HU £130
£1820
Your turn..
Ive had the car a month or so, only money ive spent is a tenner for an itrip and a tenner for a wheeltrim. Not bad. Things are going to go soon, need 4 new tyres, brakes are about to go.
technically did pay 100 quid to get the timing belt done, but that was included in the price of the car really.
Mondeo ST24 - Owned for 1.5 years.
Service - £300
New Alternator & Battery - £300
MOT - £35 & Failed
Suspension kit - £500
New Brakes & Pads - £180
Abs Sensors - £100
Various bits & bobs for Re-MOT - £60ish
Alloy Wheels - £500
Car PC - £200
Re-MOT & New Brake lines - £100
£2275 - ouch!
Did turn out to be a dog I bought! Fine now though!! Probabally other things I have missed off.
Garage Vary Front Lip £120
Sideskirts £230
Eibach Lowering Springs £120
Mazdaspeed/Ray Volks MS-01R's with nearly new Michelin Pilots £200
Total £670. Not bad really, but next month I will have some labour costs to pay for.
Edit: Ohh I've had the car 5 weeks :p
Various bulbs £10
Replacement headlamps £36
Steering column bearing £8
Inlet manifold gasket £2
Steering rack gaitors £8
Paint + sundries £20
Total of £84 in 11 months. Old cars are so unreliable and expensive to look after.
Ford Fiesta 1.4 Climate 2006.
Coming up 3 years ownership.
O.Z Superturismos with tyres = £800
K&N Cone Filter = £70
Subwoofer = £300
Cleaning products = £100+
Bosch Wipers = £30
K&N Panel FIlter = £40
Magnecor Leads = £40
NGK Iridiums = £20
Services at £80 x 3 for each year
M.O.T = £26
Castrol Magnetex = £60 (x3 at £20)
Pirelli P Zero Nero = £150 (x2 at £75)
Jet washes = £100+ :p
Eibach Lowering Springs = £80
Spring fitment = £30
There's probably a hell of a lot more but that's off the top of my head...
A load of stuff has been covered on warranty though.
Had the car a week, done 500 miles so far
New tyres all round - £170 (yay for small alloys)
Genuine renault sport mats - £50
Nightbreaker bulbs for main beam & new sidelights - £15
New Bosch wipers - £10
Just consumables really that needed doing.
Mine is in the Minus :D
I had chipped the screen price from 675 down to around 500 & then my mate bashed it down a tad more to 475. I pulled a fault on it since then though & a new price of 300 quid has been arranged/decided :D
A most Honourable deal :cool:
O yer & I sold my jeep same day for 150 so the Saab owes me 150 quid :p
Man I am so Budget :p:p:p
Replacement Thermostat Housing - £47
Thermostat , sender, screws, plug + gasket for above - £30
New wipers - £15
Smooth rear blade - £12
Miltek CatBack - £340
Braided lines - £80
New rear pads + fluid - £50
2x rear tyres - £220 fitted.
Service - £120
Two MOT's (first failed on rear tyres >.<) - £80
MSD Ignition system - £140
New sidelight bulbs - £8
9006 Audiophile HU - £200
Ford Factory Sub + Amp - £100
Think that's it!
More power to you Malc :)
About 1 horse more power though, Well it feels that way :(
Kin overweight piece of lard this thing is I can't wait to sell it, I'll MOT it April & then move it on & get something better suited (translate that into I'll get whatever I can get as cheap as chips & either run into the ground or make money on)
Blatantly though I do want J69's old motor but he keeps blanking me :(
:p
S2000 in 1 year
Gearbox/diff/engine oil £100
Brake Fluid/Clutch Fluid £20
New Spark Plugs £40
New Brake Pads £35
Air Filter and Pollen Filter £40
MOT £10
2x New front Tyres £190
And taking it in Monday for all bushes removed and greased and geometry done! £300
£735 :(
Cambelt + water pump + aux belts £400
Tyres 1st Set £500
Tyres Rear £250
Respray and new trims/weather strips £1000
Recent major service inc £1700
Power steering hose
ECU
discs + pads
steering UJ
Hicas outer track rod
water hoses + bypass
battery
New interior £200
TOTAL £4050
thats about it other than bits and bobs.
Tyres £140
New wheels with new tyres £400
Powerflex Wishbone and ARB kit £100
Standard Complete engine x 2 £250
Standard bottom ends x 2 £100
Williams engine £450
Williams ECU £60
Front shocks £100
Rear shocks £45
Wishbones £25
Rear wheel bearings £60
New discs and pads all round £110
Solid engine mount £25
second hand doors £50
New battery £55
Skuttle indection kit £150
Battery relocation kit £25
Repair work when someone backed into the front (£850)
Radiator £75
Gearbox £50
Clutch kit £60
Head gasket set x 5 £140 :p
alternator £15
New tailgate although damaged in transit, unusable:rolleyes: £150
Repairs to sill £50
All fluids about £250
New front springs £60
Top bearings £25
Various clips and bolts £15 ish
Cambelt kit £75
Cambelt £25
Water pump £25
I wont included all the paint i bought to spray my car by hand :(
Thats all i can think of currently ;) Been on the road for less than a year although i've had it since March 07 in which the headgasket went several times between then and when it was road worthy.
£4010 :o
Primera GT - owned for 1.5 years
First service and MOT -£450 (2 new CV boots, new tyre, oil + filter change + brake fluid change)
Battery - £70
New set of alloys - £170
Front set of tyres for alloys - £140
Oil topups - £50
New pads - £30
New discs - £50
Exhaust backbox - £70 (and a lot of swearing!)
