Hi peeps. Been out of the PC game for 16 months (traveling). Got back, grabbed GTA IV and Far Cry 2 and now it seems I could do with some more graphics power.
GTA IV plays fine(ish) - around 24fps average during the day, but at night with water on the road it chugs a fair bit. I can crank down settings a bit more but to be honest, I don't want to! Running mainly Medium with the odd high, and 21 / 18 as my draw / detail distance.
FC2 runs fine until I'm in a vehicle. Also get some chug on foot occasionally.
Running a 1280x1024 panel, on a Dell XPS 700 (Nforce 590i), 2Gb ram, E6700 2.67 Ghz proc. With two 7900 GTX cards in SLI (512Mb)
I've done a load of reading and it seems the GTX 260 is a good choice and price point. I get the impression it's about 2 times faster than my current SLI setup (running ONE 260). It's hard to judge as benchmarks for the 7900GTX are usually run on older games and versions of 3D mark, and benches of the 260 are run on newer games, so hard to compare. But I've got a good general feeling.
The 260 OC cards (640 clock and upwards) seem a good choice as they seem to grab about 5 to 8 FPS over the standard cards and come close to the stock 280. I want to avoid doing the OC myself as I've got put off by trying with limited success with my SLI setup. The extra shaders/pipes? on the 216 cards seem to make very little difference, though at the higher clocks the 216 spec seems to come as standard.
Does what I've worked out sound about right?
Also, I've been running 4:3 panels for years (I have 20" NEC) and I get the impression that since I've been away everyone has gone widescreen. Are the games now supporting them natively? With all this new power form the 260 maybe it's time I went wide. Is there a "standard" resolution people tend to go for?
I'm on a budget, so Upgrading the card, and possible a new screen are my main options at the moment (motherboard is next to impossible to upgrade on the XPS 700 - proprietary BTX)
