How much have you spent?
It is, but I'm driving it less and less, its probably only covered 1,000 miles this year so far.
As soon as its back to its former glory, its gone.
BMW 530i Sport E39 since September 2006
Tyres: £900
Wheels £400
Laser Allignment/adjustment @ £120
3 MOT's 1@£55 2@£27 = £109
Windscreen excess @ £70
1x Oil Service @ £140
1x Inspection I @ £210
1x Brake Fluid @ £29
1x Oil Service @ £100 (Booked not paid for yet)
HID Retrofit £140
Unscheduled Repairs £1200ish (Wheel bearing, cooling system, heater blower motor, rocket cover gasket, suspension off the top of my head)
Clutch £220
Aircon/Aux drive belt/tensioner replacement £100
3 years tax @ £600
3 years insurance @ £3000
BMW Business CD Player/Multi Info Display Retrofit £120
Intravee Ipod retrofit £200
Number plates £250 + £30 printing
Various bodywork touchups (dent removal, had a door sprayed to remove a chip as well) £150
Replaced all side rubbing strips also, £60
Subtotal: £8388 excluding fuel and purchase price
Less:
Sale of OEM changer from Ipod upgrade £130
Sale of OEM Radio from Business CD upgrade £190
Sale of original wheels £450
Total less income: £7578 (£4578 excluding insurance, £3978 excluding insurance and tax)
Edit: I keep forgetting stuff and CBA to keep editing. Added £200 to cover wipers, brake pads, random bits of crap and other stuff I can't remember inc topup oil etc.
Wow. Although some of the stuff was done for the sake of it - the clutch didnt need changing but the gearbox was out so BMW did it for parts only etc.
Your car's been keyed? :eek:
Seems the towns council estate scum have taken to using our road as a cut through, needless to say that all three of my cars (before I got shot of the volvo) got keyed outside the house, along with countless neighbours cars.
Scum :(
Owned from new - will be 4 years old in June.
4 Tyres - £370
Wheel Alignment - £free with above
3 Dealer services - £360
1 MOT - £35
Extras :
Bosch Aerotwins - £20
Uprated Headlamp bulbs - £25
Osram Silver indicator bulbs - £20
£830
servicing and routine maintenance (diff oil change, thermostat change, coolant change, gearbox oil change, brake fluid change, front pads, droplinks and a servive) = 1,000 ish
New battery - 80
SatNav, bluetooth and intravee (iPod connectivity) upgrade = 500
Tyres = 1,020 (2 fronts 4 rears)
Fixing Air con = 1,000
Exhaust = 600 (net loss... got an aftermarket exhaust, decided it was too loud, changed back to stock)
Oil top up bottles - £45 or so
So... about 4,250
It's currently in for a few bits (having bank 1 VANOS looked at as won't adjust the exhaust cam to the full range available) and also having a crank position sensor replaced and had an exhaust rattle fixed.
Up soon.... discs and pads needed all round, differential leak and a few other bits to be sorted in the next few weeks.
Not including the tax (220) insurance (1,200 a year), MOT (50) and about 5k in fuel.
Time owned.... 11 months and about 22k miles.
15 Months of ownership
Pads £400ish
Servicing £700ish
5 Tyres £1300ish
Geo £190
Warranty £1500ish
Wheel Refurbs £360ish
£4410
Might of missed some bits but sounds about right.
How many miles do you do a year?
Is this for the Gt3 and if so is it a yearly service? or 2 years or 12,000 miles?
Fiesta ST bought last week.
Nothing spent yet, front rubber will be replaced soon however.
Previously owned a 54 reg Renault Megané. Put it this way, I wont be buying French again :rolleyes:
