what card doesnt fit inside a antec 900?
5 Mar 2009
North East
i am currently using a 8800GT 512Mb wanting to upgrade but would like to know what cards will have trouble fitting inside my antec 900 case?
You might get a 4870 in there. I would guess just about get a 1024mb version
have you got a antec 900?
4870/4870X2/GTX295 any would easily fit into the antec 900 case, only problem u could have is if theres anything in the way whats connected to your motherboard, depending on what board you have got
Well, as I understand it the 280 is the longest and also very high/wide at the back, and that fits perfectly......EXCEPT you can't have drives in the bay in front of it.
my antec 900 and u could easily get a a Hard drive there....
its kinda hard to tell from your pic mate a bit dark and lots of lights just like a disco:D
not bad photography to say i was in a bit worse for wear when i got in :p
but im wrong and he is right u can't get HD in that bit, so guess that will only leave you with 5 HD slots :D
Longest card is the 4850X2 @ 28.5cm - it's around a centimeter longer than the GTX. :eek: :)
All other current consumer level GPU's are shorter.
gt
luckily i installed all my hard drives in th bottom cage as my 8800GT was worrying me so its all good thanks for the help guys htink im gna pick up a GTX260 on the cheap likes
