can someone explain the diff between 2 laptop processors?
21 Jul 2005
im talking about the P9300 and P9400 processors, apart from being newer tech, whats so good about the P9400?
and is it worth the extra premium for a P9400 --how much of a step up in tech are we talking, pentium M to core 2, or less like, core duo to core 2?
google doesnt seem to be giving me anything useful! :(
Core 2 is Core Duo.
The only difference between those two are speeds. And possibly bus speeds but I couldn't tell you.
well yes apart from the different speeds of a P9300/P9400, is there any tech that the P9400 has that makes it a must buy over a laptop with the older processor?
This would seem to suggest the only difference is the speed, P9300 is 2.26 where as P9400 is 2.4, so I doubt it would be worth the premium (as I presume you're talking more than £20-30)
ah yes thats the sort of info i was after, so its just a slight bump in speed for the price, seems the bus speed and all that is the same.
cheers.
