Hi all,
Decided I am going to give my old mk3 golf away to my brother & stepdad to use. As such, charged the battery and it started first time. Been sitting for nearly 18 months and started once every 6 months.
Was going to move it out on to the drive so I moved the mk4 golf and then went to roll the prelude back as the battery is flat on it. Only for it not to move at all.
After having a look the back pads seem to be fine but the front ones look rusted on
What's the best way of sorting it?
Charging the battery for it now so hopefully after a few hours it will have enough to start it and bang it reverse and try and force it back :S
What's the best way of sorting it?Charging the battery for it now so hopefully after a few hours it will have enough to start it and bang it reverse and try and force it back :S
