Crispy roast chicken skin
Caporegime
13 May 2003
Warwickshire
We're having roast chicken for dinner tonight. I've tried various things but can never make the skin really crispy, so I'm hoping to get some tips on how to achieve it from the OcUK chefs.
At the moment we have a chicken that's been sitting in the fridge for 24 hours with skin exposed. I am planning to rub the skin with freshly ground black pepper and coarse rock salt before cooking it on 250 degrees C for 20 minutes then 230 for another 40 minutes. This time I'm going to try it without rubbing any olive oil into the skin or basting it with butter etc.
I have a blowtorch but this just burns it and seems to taint the flavour of the skin.
Any other tips for a really crispy chicken skin?
PS I've already tried the kill it with fire, nuke it from orbit, etc. approaches.
I dont do anything special, bit of oil + some chicken oxo over the top. In the oven @ 180 for about 1.5 hours and voila tasty crispy chicken skin!
decent roasting tin!
I bought a hard anodised one the other day for £40 quid and it was worth every penny!
i normaly cook it covered then for the last 10 mins or so put it in uncovered. rub some butter or oil on the skin before cooking it.
I just cook my chicken in an open tray. I put some black pepper and olive oil on it, but nothing else (and I don't really rub anything in).
The key thing for crisping the skin should be the temperature of the oven. I have mine at around 230C. Perhaps your oven isn't hot enough?
I usually put a bit of water in the bottom of the tray when I'm cooking a chicken. I'm guessing that the resultant steam and humidity is what's stopping my chicken skin going crispy. Have to stop doing that.
Start it on 220 for the first 10-15 minutes depending on size, then reduce to 180. The higher temp cooks the skin first and helps to seal the juices in.
A little oil and salt should be all that's needed for crispy skin. Dry the chicken with kitchen paper before you start otherwise the high temp is wasted evaporating the water.
