The tips and advice thread
Never say you can out run a car at 5 miles an hour, then proceed to try and get out hte car whilst its still moving. You'll never catch up from laughing too hard....
Trying is also the first step to failing
Well I used it and it works obviously there are some people that just shouldn't be allowed either butter or cutlery. ;)
Aero
Well your tip's success clearly depends on the propensity of the bread to breakage and the temperature / viscosity of the butter.
*Shrugs* I find it works and for another tip try not to stand on plugs or lego firstly because you can hurt them and secondly because it can hurt you too! Health and Safety kids!
Aero
Be yourself, no matter what your inner perceptions are :)
Don't tell your mates everything: they are trustworthy only when sober.
Eat more curry: it's good for the soul :D
While doing a levels put in 100% effort, have a thorough understanding of what will be on the exam. If in doubt ask teacher. My biggest piece of advice is to not fall behind, in fact get ahead of the work, read ahead. Follow these and you will do well.
On a similar note, when preparing for exams go over the past papers from the last 4 or 5 years. Often you get very similar questions year on year and can spot what areas will come up. Similarly look at course schemes and sample answers to make sure you don't miss easy marks.
never arm wrestle someone twice your size - the result is having to go through a operation and sticking a metal plate in your arm.
