I play on Karak-Azgal, which is a rammed server dominated by Destro!
Ok worked it out for myself.
Anyone know how to cancel quests? I think one has messed up and I cant complete it.
To find quests objectives its easy, look at the map (m key) and every big red circle is a quest objective.
I'm not active a lot these days, but I'll try to give you a hand sometime, what is your name?
Open your Tome of Knoledge, go to the quest tab, select the quest in question, click on abandon.
Whats the cheapest this game can be bought for? I didnt realise that you had to buy the game after the trial. I thought you could just buy a gaming card and continue.
Shame as it will probably put me off continuing as I could have a new game that I can continue playing for free for the price of this.
£9.99 is the cheapest, It's a good game when I played it, but I left basically under the same reasons I left WoW. Playing Darkfall at the moment which is awesome but at the same time pathetic.
How can it be both awesome and pathetic?![]()
I play on Karak-Azgal, which is a rammed server dominated by Destro tanks!
33 WP.Mat I'm in Celtic Fist on Karak Azgal, other ones I'd suggest talking to are Griffon Knights and Disorder.
Karak Azgal is now Order dominated, but T1/2/3 are pretty even, it's only T4 that Order seem to have the upper hand in at the moment, it's amazing how quickly things switched around just prior to 1.2.
How does this tier system work, does it just open up the map more or can you walk anywhere even if you are considered a tier 1.
Please correct me someone if thats incorrect. Thats just what I've observedYou can walk anywhere. You just can't join the PVP scenarios of the Tiers. Tier 1 is pretty much controlling an area whereby Tier 2 you've got CTF and stuff like that its pretty fun.
So for example.
Level 1-12 = Tier 1
Level 13 - 25 (i think) = Tier 2.
And so on...Please correct me someone if thats incorrect. Thats just what I've observed
Question. Does OCUK have a guild on Karak Azgal Destro? Or does anyone play there? I play as Anjuna - -- Female Sorceress! Level 16. Can't wait till i get a mount. Dont even know where to buy it or how much it costs lol
sammy
Look on the maps of the regions you are in, it shows you which areas are different tiers. Usually quests take you through the tiers at the right times, though you'll probably need to visit neighbour regions to do it solely on quests.How does this tier system work, does it just open up the map more or can you walk anywhere even if you are considered a tier 1.
So what do you do when you get to T4?
