Patriot 'Viper' 6GB DDR3 PC12800 Tri Channel Kit - Just £88.99 Inc VAT
15 Feb 2006
Staffordshire
*******Patriot 'Viper' 6GB DDR3 PC12800 Tri Channel Kit - Just £88.99 Inc VAT*******
In Stock Now:
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 8-8-8-24 timings and is available in 3GB and 6GB kit capacities. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (8-8-8-24)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- 100% Tested and Verified
- Lifetime Warranty
- RoHS Compliant
- XMP Ready for Core i7 Processors
- Tested and compatible with Intel? X58 Express Chipsets
Buy Now @ Just £93.99 Inc VAT
:O:O, bargin
i have this in my current PC and used Patriot ram in my pervious PC too. Overclocks amazingly and is stable too.
i paid over double that for mine - ddr3 is becoming affordable now
tempted to get another 6gb.
OcUK Review
By RJKOneill
Test Bed
i7 920
Asus P6T Deluxe
Patriot Viper
Akasa Nero with push pull delta fans
WD velociraptor
BFG GTX 280 OC
Corsair 1000W PSU
Dimas Tech Bench
Stock Bandwidth
920 overclocked to 4GHz memory at rated speed -
920 overclocked to 4GHz memory at tight timings of 8-7-8-22
920 overclocked to 4GHz memory at tightest timings of 8-7-7-21
Latancy test @ tightest timings of 8-7-7-21
I just spied this as I was perusing RAM for my incoming i7 upgrade. I reckon 12GB of this will do nicely :)
i am really impressed with this kit - after working closely with AndyOcUK and researching what enthusiast users want, OcUK really has got a great triple channle range
this patriot kit is on par with my own corsair dominator 1600 kit [and boasts tighter timings]
if i didnt already have i7 - i would be considering an upgrade
whilst not as tight as the £70 OCZ kit - it has the advantage of running tight timings at 4GHz on a 920
which is more than enough
my own corsair dominator 1600mhz kit will do 1533 at 4GHz - nevermind running at its rated speed - especially at tighened timings
and it costs £70 more!
speaking as an enthusiast rather than an OcUK employee... for less than £100, you could do a lot worse - competitors are STRUGGLING to keep up!
plus, it looks FANTASTIC
would look great in a gigabyte board with their current colour scheme
fancy testing how far you can push the clock speed, im hoping you might get 1950mhz @ 9-9-9. BTW you didnt say what voltage you used on the ram to get 8-7-7-21. Have you could try pushing the clock speed to the max with 8-7-7-21 timings too maybe it might get 1700mhz with those timings, would be nice to know.
Yeah, it would be great if you can overclock it to 1800mhz, like the ocz reaper! http://www.overclockers.co.uk/showproduct.php?prodid=MY-152-OC Plus it would save me £20 :)
Would it be possible to OC to 1800mhz?
