*******Patriot 'Viper' 6GB DDR3 PC12800 Tri Channel Kit - Just £88.99 Inc VAT*******
In Stock Now:
Patriot Extreme Performance (EP) Low Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 8-8-8-24 timings and is available in 3GB and 6GB kit capacities. Equipped with Patriot ACC (Aluminum Copper Composite) technology, these modules are designed for maximum performance and stability under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (8-8-8-24)
- 1.65V
- Equipped Patriot Viper Heat Shields with integrated ACC (Aluminum Copper Composite) technology
- 100% Tested and Verified
- Lifetime Warranty
- RoHS Compliant
- XMP Ready for Core i7 Processors
- Tested and compatible with Intel? X58 Express Chipsets
Buy Now @ Just £93.99 Inc VAT
In Stock Now:
- 1.65V
- Lifetime Warranty
- RoHS Compliant
