E8400 - Dead on Arrival?
17 Feb 2007
Redditch, UK
Hi guys,
I've recently bought an E8400 from OcUK to upgrade from my E2180. I installed the new processor, booted up and thought I was away and sorted and looking forward to getting dirty over clocking this E0 stepping CPU.
However, as soon as I put the CPU in and booted, I went straight to the BIOS to verify my processor was picked up. It was and my ABIT IP35-E was showing the processor with the correct name and speed. In the hardware monitor section of my BIOS however, it was registering at 98 degrees C!
I cleared the CMOS, booted back up and this time went straight to windows rather than check again in the BIOS. No such luck - blue screen after the Vista progress bar comes up again, and that's as far as I seem to be able to get. I thought it might have been my heatsink not fitted correctly, so checked that and it was fine. I then thought it might be my BIOS file out of date, so flashed it to version 18 (latest version from ABIT) but still the same behaviour - 98 degrees in the BIOS hardware monitor and unable to boot to windows with a blue screen after the Vista progress bar.
So, does this processor sound dead to you? I currently don't have any other system I can test the processor in to verify if it is indeed DOA or not :(
Any help would be appreciated.
My specs are: ABIT IP35-E (with latest BIOS version), 4Gb GeIL Ultra Low Latency PC6400 DDR2 RAM, Vista 64 Home Premium, XFX ATi 4870 1Gb
EDIT: Reading on t'internet that quite a number of people have managed to get an E8400 working with the IP35-E's. Some out of the box, some with BIOS update - leads me to think this may be DOA even more. Might be worth returning to OcUK and swapping for an E5200 or something.
Not sure iof this will help but can you turn off thermal shutdown or whatever it is called and then try booting up? it amy help due to the CPU thinking its at 98'
This thread may be of use. Does your board even support E0 Wolfdales? There will be no more bios releases either as Abit does'nt make motherboards any longer and there was even a rumour that they had gone into liquidation.
It should I have the first revision in my IP35 Pro. Im sure a stepping revion is not that much difference in CHIP tech.
It can make a big difference actually.
Looking at the Abit website your cpu is still under test - since July.
http://www.abit.com.tw/cpu-support-list/mb/intel_p35_ip35-e.htm
Is there a possibility to check your cpu in another motherboard and double check the HSF is installed ok.
It's not going to change from testing as Abit has gone. Good advice about testing in another board. I doubt if it's the cpu at fault.
I would say the chip is ok, had the same on my rampage formula board needed a bios update to read temp correctly.
mine was an e8600 and the board said that was at 98c, it ran other 45mn chips just this one threw it.
forums.he xus.net/abit-care-h exus/149415-bios-updates-intel-e0-stepping.html
I think its bios 18 you need, is this the one you are running?
It is unfortunately - the official BIOS 18 from ABIT. To be honest I'm a little unsure about using unofficial BIOS files.
Might return it and get a Q6600 maybe - they're fully supported by my IP35-E I see.
