Never done mine at all. Been going for around 4 years now with no probs.
I clean it every month. It clogs really fast because I use tap water and the dust gets in which forms a gunge.
I also have to keep refilling it everyday because it evaporates and the reservoir leaks a lot.
you must have had to refill it a couple of times, I don't see any components over a year old I don't think so there must be a bit of block changing going on?
Lol it evapourates you must be running at 100 degrees+?
I use a large plastic 30litre container on top of the case as a reservoir. I cooled it with fans blowing air into the water. Its a lot easier than using radiators but if I left it on with the window closed moisture condensed on the ceiling. My jackets went mouldy due to moisture. I don't recommend this cooling method.
I just recently changed the design, I now use a radiator and I've covered the reservoir with clingfilm to keep the dust out.
