Pressure washer taken layer of paint off!
Incorrect, this is caused by a defect in the paintwork. There is nothing wrong with using power washers.
Theres plenty wrong with not using them correctly.
Lame attempt tbh. :p
You worry when you take the paint clean off and leave bare metal! :eek::o:D
i think the instructions typically say 3 things.
dont spray the machine
dont spray animals
dont spray other people..
why? because theyre pretty brutal, anyone who has accidently jet washed themselves knows that, hence you dont put it close to your paint
dont spray animals
How many men do you know that read instructions? ;)
Because the instruction manual is so clear?
You don't need to read the manual, just use common sense? If you drop a sponge on the floor and start washing your car with it, there will be marks and scratches, it doesn't say this in the 'instructions for sponges'.
Like my 1 year old Punto. Took it back and was accused of trying to sand down the paint to the metal so I could touch it up! Promptly told them where to go. Got rid of it 6 months later and never touching anything Italian ever again. :mad:
My MR2 blew a head gasket, so I'm never buying another poxy Japanese car again. :rolleyes:
That's the spirit. ;)
Was someone asking how on earth you can use a pressure washer wrong?
Not me, exhibit number 1 - I was just trying to get that extra stubborn spot off, edging ever closer and ever closer... I knew it would happen but you tell yourself it'll be fine... :p
Had some of this although very minor around near my sideskirts. I guess it must have been resprayed similar to this. Never concerned me too much as it was mostly hidden.
