I'd get a pair of cheap stands (or even wall brackets if you can't fit stands in) and, depending on budget, either upgrade the source to an M-audio soundcard (decent onboard DACs), or a dedicated DAC (£100 up).
The speaker cable and interconnect are also worth looking at, but in terms of sorting the sound out you've got to look at the speaker positioning first.
Cheers ste. As a temporary solution I've moved the one in the bookshelves onto a speaker. And I'll go grab some blue tac now ^^ . But I'll have a think about the long term. Like I mentioned above, I'm on the look out for a massive desk and if they were positioned on either side it wouldn't be too bad. Though I'm certainly considering wall brackets. It would leave the desk less cluttered for a start!
Regarding the DAC (and to be honest that price tag rules it out I think), is it basically a sound card in a box? I.e. would I not need a sound card anymore if I bought one?
