Also, i noticed that even against you, using light command throw when you got up from a knock-down was very effective. I just felt lame using it, especially several times in a row. Need to decide whether that is indeed a viable tactic or, as i like to call it, 'a gief'.
Still need to work on my pokes too...
use it! its not lame if it works!
im guessing its main advantage is its priorty, of course it beats out my pokes which is something you should consider!
doing things multiple times in a row is also not lame, its actually a good way to mess with someones mind (mind games), but thats a whole other discussion right there
Those of you who use the standard PS3 controller, what button config do you guys use? Especially ojste.
The way I have my layout, I don't have a LP or LK on there which I NEED!
left trigger
focus
left button
throw
right trigger
3x K
right button
3x P
the 4 buttons are: MP HP MK HK
not binding lp/lk is a BAD idea!
my buttons are default settings with 2 binds switched around... default settings has hp/hk one one side of triggers and x3 on the other side, i prefer it old school way with hp/hk on the front set of triggers and x3 on the rear set.
throw/focus attack buttons are not needed imo (with default controls anyway) as your thumb naturally goes over the buttons needed to press them.
