Where to get custom numberplates quickly? Road legal
19 Mar 2007
Hi!
I'm just trying to find anywhere I can get some numberplates which are road legal quickly as I'm off to France and the numberplate has some condensation in it and is snapped in half! Ha!
I've seen some sites but they all require documentation but I am just trying to find some sites that don't really require that, but if there isn't then I will have to then..
Cheers! :cool:
www.fancyplates.com
All plates and reflective materials we supply meet the requirements of BSAU 145d, however for our Standard UK plate customers, Fancy Plates guarantees peace of mind in that all plates ordered through this constructor are suitable for use on UK public roads and will pass any MOT/PSV tests.
try demonplates.com
they ve just supplied me mine, all i had to do was fill in an online address check for which comfirms to them the vehicle is registered to that address..
all their plates are bsau 145d marked road legal and will pass mot tests..
delivery is usually within 48 hrs or sooner depending when you make the order..
hope this helps..
Anyone know of a place that does fully laminated plates?
With mine being right above my exhaust I have problems with the heat causing the printed back to peel off so I need something a little more heavy duty really, or at least contructed in a different way.
Mate of mine just failed his MOT due to missing BS code on his plates.
Another friend failed due to no BS number or postcode information.
Looks like the centres are tightening up as reported.
