Vista 64 to Vista 32
because I want to use the Dragon NaturallySpeaking, and they don't do it for Vista64
Ahhh right I see where you are coming from now, still my answer remains the same, it should work on the 64 bit version as well as it does on the 32 bit version of Windows. C&C3 says 32 bit only, but runs happily on my x64 system. Dragon should not be any different from my reckoning.
Right click the file you want to install, go to properties, then go to the Compatability tab and tick the the box Run this program in compatabilty mode for: Usualy Windows XP.
Worth a try can't say it will def work though :(
What 1 I select in list?
sometime it does work if you install in 2nd hard drive instead of master drive that wee bit tricky - when i tried to install other games like this and didnt work on master drive -- so removed it and reinstall and put into 2nd drive that worked prefect without problems - it work either 32 or 64
try run as admin in Vista or like some of this screenshot as select "Windows 95 or XP" that can work as well.
Ok well I got v10 and try to install it and this is what happens:
Before install
After
scaled.php
